goodday
DOES ANY HAVE A VIBRATION SOUND COMING FROM THE HOOD AREA, SOUNDS LIKE BODY PANUELS, BUT CAN NOT STOP WHEN I PUT MY HAND ON THEM, THE RATTLING IS THERE ANY TIME I,M OFF IDLE SPEED, I HAVE A 06 APEX RTX WITH 4000 MILES THANKS GOODDAY
AttakDog
Most likely it's your primary clutch rollers at idle. It's a known item, but not a problem. You can bump the idle up slightly if it really irritates you. I have over 9,000 miles on my clutches just keep blowing them clean with compressed air and change the spring occasionally. They had a update on some of the 3 cylinder Yamaha's where they put in some shims to quiet down the rattle but not on the 4 cylinder sleds that I know of.
biglew09
hello my 09 rtx has a vibration at idle but if i push downon the head light and gauges it stops i'm new to yamaha..
vice108
Yes - I sometimes get an annoying buzzing sound from the gauge area. Just go faster!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
vice108 said:Yes - I sometimes get an annoying buzzing sound from the gauge area. Just go faster!
HONDAFIXER
Mine was at the radiator above the right footwell
Mine vibrates a little at the very front tip of the sled, behind the front bumper, where the lower plastic body panels come together.
LJ 452
Put a piece of 1/4" stick foam around the front of the bar that the hood latches on to at the front. My Apex had a vibration and that seemed to help. I had to fix it immediately after giving my buddy so much crap about his Cat rattling my fillings out.
