Bogey ice build up XTX......
Phaze
NW WI
2012
Am I the only one that has ice built up on both sides. Bogeys dont touch the track. Back of suspension tilts up which I believe is normal..
Thx...
my apex xtx did that until i put on the oversize kimpex wheels. the 09 rtx i made into an xtx, i did not put those wheels in that location as i did not have the mounts. as there is a shaft to space the rails apart there, i swapped it out and modified the old kimpex kit for the add axle and wheels for the enticers and put it in instead of the stock one. only time that those wheels have stuck now is when it was stuck in the slush on the lake overnight.
Thanks for the info. I thought maybe my slides had to wear a little, although, I'm running Duponts. Do you have a link to the larger wheel? Not trying to be lazy, just want the right one..... Thx
royal distributing part # is 04-116-96s witch is 5.118 od. that is usually the kimpex part # for the wheel. excel makes oversize wheels for this location as well. i think barn of parts sells them.
Excell motorsports. com
