mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
Will any other brand wheels fit the nytro xtx skid?
mcamzr
There have been people that have put Doo and Polaris wheels on. Or excell X wheels.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
All the wheels from the old VMax, SX. SXR chassis are the same diameter as your wheels and have replaceable bearings. I went to a used snowmobile parts dealer in my area and bought the best used wheels he had, replaced all the bearings and put them in. Now all I have to do is remove the wheels and clean/re-grease the bearing each spring. Totally solved my idler and tensioning wheel bearing failure issues for a fraction of the cost of and Excel set or other aftermarket brand.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
I used Ski Doo idlers. 6 total
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
I have ski Doo idlers on outside the rails (4) and X wheels between the rails (4). These wheels are about 5mm larger in diameter than stock. It helps with slide wear. I also have the DuPont sides as well. If you use ski Doo wheels, I believe there is a spacer you have to put on the idler wheel mount due to the bearings being a different size than stock. If you are looking for stock replacement wheels I think Kimpex sell
