WINDER1987
I didn't find a whole lot of info searching this what is a good quality digital boost gauge that won't break the bank? Thanks
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
The best boost gauge you can buy is the GAP flasher from hurricane, lol. Blue tooth to your cellphone or ipad, definitely not cost effective tho.
Depends how cheap you want to be for the boost gauge. AEM is likely one of the better ones. You can buy really cheap ones on ebay, but you have to question the accuracy on those.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Koso x-1 is just boost,and it 200 bucks,i am getting there x-2 boost a/f and temp. $426.00I didn't find a whole lot of info searching this what is a good quality digital boost gauge that won't break the bank? Thanks
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
@1100saber has one for sale
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
WINDER1987
Where do you plan on mounting it I would like to be able to remove my hood and side panels without having to worry about wires. Btw eBay has that gauge for $366 just FYIKoso x-1 is just boost,and it 200 bucks,i am getting there x-2 boost a/f and temp. $426.00
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Nospro has it mounted onto his plastic area where the heated seat switch is,with Velcro,for easy removal.
WINDER1987
That's a good idea how are these gauges working with the sidewinder? I thought I read a while back that td didn't recommend them
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
WINDER1987
How do you like the failsafe is it hard to install and program? How do you remove your hood with it on?I use the AEM failsafe. Has boost and AFR.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Your gauge was what I was going to buy from Evo but after all the new laws in maine with noisy exhaust,i decided to get a gauge that I can mount down low,if I had the gauge where you have yours mounted,it would bring attension to my sled,may be modded,and than they would start looking closer.I use the AEM failsafe. Has boost and AFR.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
I spent a lot of time on the install to make sure I could have quick connects on the vacuum line, power, and AFR cables. Works great and easy to setup with the USB connection to laptop. Have values set for AFR, if they get close the gauge will change color and flash. It’s a nice feature for.
