boosted gearing
NYTRORYDERAK
Fairbanks, Alaska
What are you boosted guys running for gears in the mountains. Have a 09 mtx with a super running 8lbs. I have 19/40 now from when I was na but I was wondering if I should go back to 20/40 now that I have the extra power.
22/40 around 12psi
Im not elevation like you boys, but my xtx we did a 24 top from a 21 and it flys...so i went up 3 on top with a chain change, dont know if it gives any help but its what im doing!
I have my chain case apart right now changing tracks so I think I will try the 20 top instead of the 19 i had. More power with boost so it should pull it no problem, or it sounds good at least. :Rockon:
