stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I just wanted to report on the throttle lever that is used on all the Japan made sleds from BOP.
The feel is subjective, but since i had 30,000 miles on the Japan model, i figured i would like it.
I DO!
The best thing is ROCKMEISTER helped out with the heater & it is HOT!
Also the lever comes with an actual c-clip unlike the cheap one timer POS clip from AC.
I DO!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I was just about the start a thread on thumb heater....
With these temps, my hands cook just fine but thumb not so much!
So what exactly makes this one hotter then say, my apex was? This cat heater feels quite hot, but not quite enough recently for these temps.
Pics? Cost?
thnx
Dan
Pics? Cost?
thnx
Dan
krm
- Apr 22, 2016
- ny
I have one and it is much warmer than the oem one .And the lever fits much nicer to my hand
krm
- Apr 22, 2016
- ny
Dan look it up at BOP
krm
- Apr 22, 2016
- ny
$110 japan throttle kit
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Pics? Cost?
thnx
Dan
The ROC added a little black box gizmo thingy to beef up the heat. The underneath is also molded rubber compared the foamy felty thingy on the stock version.
I'll go outside & take a pic for you Dan. This 7 above is warm compared to the negatives i rode in last weekend so i'll be ok...
Q. Arrius
- Feb 6, 2015
- Indiana, (central)
- '17 Sidewinder LTX LE (red)
'12 Apex SE (black)
'12 Arctic Cat F800 snopro (129, orange)
'15 SRX 120 (blue)
''15 S.Doo Renegade XRS (Ronald McDonald colors)
Steve! You freak 'n beat me by less than hour. I was literally driving home from my shop, eager to make the same post!
I ran the SW for 2 minutes to check clutches ect. Within one minute....(if that)...Apex w/boost was freaking hot. Like pull thumb away /ouch hot!
This absolutely cures the one major fault or dislike for me. I was dreading another winter with the way it was going.
Dan: Some SWs seem not to send as much power to the thumb lever. I suspect 2 reasons: One is that the actual element isn't always affixed tightly to the backside of the lever. I had a little better heat by pushing it tight and covering with foil tape.
Second....if you're not hammering the RPMs, the voltage to the grips just isn't there. I have no desire to go full blast. Im more like the guy chugging around in his Ferrari. Everyone knows what it can do.....no need to use it until the driver wants to.
What would be really awesome, would be if Rock would do up YamiCatHeater packages! I know you could do it Rock!
Travis/Rock: you guys really helped me with this! You can't imagine how big of a deal it is for some! Thank you.
Q. Arrius
Q. Arrius
Q. Arrius
- Feb 6, 2015
'12 Apex SE (black)
'15 SRX 120 (blue)
Rock,
I know you know you're AC sleds as much as Yamahas. But if you need a SW to test fit...Id gladly run mine up from Indy!
Q. Arrius
Q. Arrius
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Q. Arrius
I win!
I used foil tape also & ripped it off for the pic.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
You guys need to just go ride! Lol
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
I rode for 450 miles below 0 with a warm thumb!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
OK so for 110 USD this includes everything? ROCs booster and the throttle lever correct?
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
How bout wiring, does the lever plug and play? How bout the ROC box, where does this plug in to?
thx
Dan
thx
Dan
