yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
How do the little fasteners work.
big_red1a
Not vey well! lol
I use 2 flat screw drivers but some do break
Billboard
Soak them with a little WD-40 or Pen fluid first.
Use a small flat screw driver to pop up the center pin--grip the center pin with needle nose plyers & lift the unit out.Haven't lost one yet.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Thats how I thought they worked, but wanted to make sure beforew I started braking them. Got them all out ok, probly helped that its 70 degrees out, probly would have broke some if it were. 15 degrees. I bet the dealerships sell a bunch of them.
bradb
I made a tool that works great and doesnt ruin them, go the hardware store and get a small end nipper (they look like a small pliers kinda) then do a little grinding on the end so it will fit into the fastener and lift up the the center part when you sqeeze the handles, sorry if knew how to post a picture on here i would. Hope it helps.yamahinn03 said:Thats how I thought they worked, but wanted to make sure beforew I started braking them. Got them all out ok, probly helped that its 70 degrees out, probly would have broke some if it were. 15 degrees. I bet the dealerships sell a bunch of them.
sleddingfarmer
If you break a bunch its way cheaper to go to a napa or fastenal store or any auto parts store and just buy them from them. They should be able to get a pretty close match to the yamaha fasteners
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
sleddingfarmer said:yamahinn03 said:Thats how I thought they worked, but wanted to make sure beforew I started braking them. Got them all out ok, probly helped that its 70 degrees out, probly would have broke some if it were. 15 degrees. I bet the dealerships sell a bunch of them.
X2 - go to Fastenal and buy a box of 25 for $7.00. They are made by Au-ve-co products part #19239. Fastenal part #0162683 a universal type for a Acura & Honda and work perfect for the Nytro. They're much easier to open/close.
Southern Renegade
- Jan 27, 2009
- Rock Island Arsenal, Rock Island IL
- 2009 Polaris RMK Shift 144
yes kinda expensive $1.15 a peice from Yamaha dealer so take your time removing them
yamahinn03
- Dec 28, 2004
- oshkosh, wi
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Thanx gentleman.
