TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I know this has been beat to death....I did a search and read some conflicting stories......
What is the proper BOV setup? Open at idle( approx 6"hg)
I have a rear mnt mcx with the BOV on the side of the intercooler and a malipassi dual spring as a second on the intake side of the intercooler.....anyone else run this one?
The one that comes on the intercooler I am not conviced its even opening....how could you check if it is?
Thanks in advance
Thanks in advance
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
you should be able to hear it dump when you chop the throttle fast. Personally I run mine closed at idle with very little spring pressure holding it closed and I hear it dumping on throttle position changes
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
so the bottom part closes at a certian psi, but is open under boost? Then when it see a vacuum the top opens and the bottom closes when it reaches a certain psi........Is ths a good BOV?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
TURBLUE said:so the bottom part closes at a certian psi, but is open under boost? Then when it see a vacuum the top opens and the bottom closes when it reaches a certain psi........Is ths a good BOV?
Bypass/Blow off vavles should be open any time there is Vacuum Present in the Carb boots.
Boost pressure will seal the Bypass/blow off valve.
I recommend the lightest spring you can get about 1.5 in.Hg
Of all the Bypass/blow off valves I have tested the Vortech Race Bypass is superior.
Ted.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
anyone know if they make smaller springs for the bov I have?
woodsrider
- Feb 17, 2005
- Lewiston, ID
Just cut your existing spring shorter to weaken the spring. Cut a little at a time to get the performance that you want. you can stretch the spring out if you have to so it will act upon the poppet.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
whats the purpose of the poppet(lower seal spring I assume)?
woodsrider
- Feb 17, 2005
- Lewiston, ID
Not seeing all sides of the whole valve, id' say it is a two-stage blowoff valve. This would allow for a more consistent or linear performance.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
would it work better to take the bottom spring and seat out and set the upper spring so at idle it would be open? I was testing it in the shop I rigged up a air supply with a tee and a hose going to the top of the bov.....seemed to work without the bottom seat and spring.....make it a single stage I guess
woodsrider
- Feb 17, 2005
- Lewiston, ID
I would try weakening the upper spring first before going single stage.
