RX1Jim
Has anyone upgraded their brake system by installing a braided stainless steel brake line? I've installed these on my sport bikes with good results, better brake feel. At the recent snowmobile show in Springfield MA I took a look at the new Cats. The only good thing I saw on these sleds is that they are using a braided stainless steel brake line. These lines look much better han the stock lines.
jimmie d
I put one on my ZR when I installed the riser mainly because the exposed copper one looked like crap. Cost $90 Canadian but worth it in the looks department.
Jim
Jim
LazyBastard
Brakes are better with some give to them... makes it easier to control the amount of breaking. I absolutely would not want the brakes on this machine to be any less springy, in fact, I would like it if the lines were a little MORE springy.
JDKRXW
LB, I can tell you've never owned a Cat. Their brakes are extremely aggressive with very little cushion. Once you get used to this..... nothing else is as good.
snowsweat
I put one on my SX-R. It is easier to avoid track lock-up when braking hard. Modulating the braking force can be done with adjusting the pressure you apply, instead of moving your fingers in and out (as with a spongy system). This is the basis for almost all brake systems advancements (stiff lines, less flexible calipers, stiffer brake levers.) I just put one on my Rage. I haven't tried it yet, but with a 10 kg squeeze on the lever, the movement went from 13-14 mm down to 8-9 mm once it was properly bled. Go for it.
Cubby's RX-1
- Nov 14, 2003
- Willoughby, Ohio
- www.cubbyscustoms.com
LazyBastard said:Brakes are better with some give to them... makes it easier to control the amount of breaking. I absolutely would not want the brakes on this machine to be any less springy, in fact, I would like it if the lines were a little MORE springy.
Yo LB, is this word "springy" A technical term??????
I do however agree with the LB on this one, I think the stock brakes are kind Of "Grabby" and lock up the skid a little to quickly..............Cubby
welterracer
I TOO AGREE.. The brakes are extremely grabby and lock up easlily..
I had a 95 zr700 with the willwood brakes and my warriors brakes are equally as good as them!! Just touchier!!
I wouldnt waste the money the braided line!
LazyBastard
JDKRXW said:LB, I can tell you've never owned a Cat. Their brakes are extremely aggressive with very little cushion. Once you get used to this..... nothing else is as good.
Once you go crap you don't go back?
impalapower
Didn't think that the lines were long enough to notice the difference between braided and non-braided.
JDKRXW
LazyBastard said:Once you go crap you don't go back?
Hey, I came over from the dark side didn't I??? The funny thing is that every once in a while, I get the urge to go back ........ I get snapped back to reality when I listen that four holer under the hood, and then everything is good again
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
That's what brought me to this brandJDKRXW said:when I listen that four holer under the hood
BlueBlood
Ditto that Mighty!
Some would argue that, particularly very aggressive riders, who can overheat the brakes. The braided lines do give a more positive feel and won't stretch when the fluid gets hot. I have overheated Polaris brakes in years past, and then your brakes just go away, not good. Just the same, I like the stock Yamaha brakes just fine too.
