WisconsinViper
I was changing my jackshaft and driveshaft bearings and I am having trouble getting the circlip back on the outside of the brake rotor. I have a 2014 Viper LT-X. The circlip does not have the two holes to use a snap ring pliers. I noticed that the newer year vipers have the circlip with the two holes. Does anyone have any tricks to get this style of circlip back on the shaft. Or does anyone know if if the newer circlip will work on the 2014 model.
2014 circlip is part # 8JP-RAH09-00-00
2020 circlip is part # 8JP-RAC03-00-00
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Newer circlip will work, you might need to ratchet strap the tunnel to pull the sides together to expose the groove for the circlip
