SKIP
I have a strange issue, I need help with.
Have a newer style hydraulic brake (off Nytro) installed on my Phazer II and have no control of my brake light...it is always on.
I checked the brake light switch which had power all the time. I removed the switch to check contacts and noticed once positioned it functioned correctly. However when installed, the position has it in contact all the time?? I see no type of adjustment available?
I was thinking it may be the wrong switch for the application, but it fits perfectly and is identical to the parts diagram.
Anyone have any insight?
Thanks!
Skip
Thanks!
Skip
Thanks!
Skip
Its the wrong switch. I had this happen once before and tried to take a switch off an older Yamaha and it would do the exact same thing.
SKIP
Wow, I just looked at the parts diagram for the 93 and it looks as if it is the original mechanical brake switch! I assumed the switch was part of the newer hydraulic assembly (not). I can't believe the switches are that similar 20 years apart!
Thanks for the heads up Mr.Sled!!!
Your welcome!!
