rockwell2
- Oct 12, 2011
Been searing here with not much luck my 2018 ltx has been developing a loud scuffing or grinding noise in the brake calliper area at low speed it can be herd no problem with no helmet on it’s crazy loud sound like bearing behind rotor is bad but more speed it goes completely away when it’s doing it I can just lay my finder on brake lever and it goes away but do notice u can feel pulsating in the lever
Sled has 1700km has been flawless up to this
Noise started at 1200km and seems to be getting worse
Just wondering if anyone else had an experience like this
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
sounds like my 2019 LTX, about 14-18 MPH? Dealer told me it was my studs, I LOL
rockwell2
- Oct 12, 2011
I’m not studded as of yetsounds like my 2019 LTX, about 14-18 MPH? Dealer told me it was my studs, I LOL
I’m taking it to my dealer tomorrow morning and dropping it off I’m worried they gonna tell me the same thing and to get use to it
rockwell2
- Oct 12, 2011
Speed be 18 to 25 when loudest in loose snow can feel it in my foot on the left side
cflorek
- Aug 22, 2015
- Grand Rapids, MN
- 2017 Sidewinder, Rush Pro-R, Polaris Indy 600, Skidoo 500ss
Mine never did this for 9000 miles until I had the driveshaft replaced under warranty and they put the upgraded brake rotor in. Now I have the rotor noise as well. Just like you when I touch the brake it goes away. Its like the brake pads are rattling on the rotor.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Let me know if they find something wrong.I’m not studded as of yet
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
I'd have a look at the bearing, as those millages it could very well be a bad bearing. The race turns on the shaft, witch generates heat, then the grease breaks down, and bye bye bearing. Changing a bad one on mine now. 2500 + kms that had bearing retaining compound. But by the looks of it maybe ran 400 -500 km turning on the shaft.
Also seen putting copper anti seize on the brake splines to stop some vibration and noises (but the noise you are describing doesn't sound like that)
Maybe check that your rotor isn't rubbing on something...
rockwell2
- Oct 12, 2011
I will update when I find anything out hope they can do somethingLet me know if they find something wrong.
I’ve noticed it the last few weekends we run a 500km trip on weekend and was getting to me the noise
Me and young fella went out to play in snowdrifts yesterday it was then with just a winter hat on I realized how bad it really sounded
rockwell2
- Oct 12, 2011
I think the run out of the rotor is not true due to the small pulsating of the brake leverI will update when I find anything out hope they can do something
Run it on a stand and noise not that loud with track off ground but can see brake pads bouncing around
rockwell2
- Oct 12, 2011
And I did check the rotor it looks ok not hitting anything had brake pads out the look good but did notice a lot of wear on back of them from the brake pistonsI think the run out of the rotor is not true due to the small pulsating of the brake lever
RAMSOMAIR
Check your primary spring it may be broken. I had all the same symptoms as you and found my spring to be broken. Changed spring and presto. Just my experience
rockwell2
- Oct 12, 2011
Thanks for the reply will check that tonightCheck your primary spring it may be broken. I had all the same symptoms as you and found my spring to be broken. Changed spring and presto. Just my experience
RAMSOMAIR
I had changed brake pads too hoping that was the issue but it was the primary spring.
rockwell2
- Oct 12, 2011
The broken spring didn’t effect engagement rpm or too end rpm?I had changed brake pads too hoping that was the issue but it was the primary spring.
RAMSOMAIR
Barely noticeable engagement rpm drop. I’ve been low on my top RPM due to the Ultimax belt
