Broken Front Shock Phazer FX
Marshall Seas
Wisconsin
2007 Phazer FX
I just inherited a 2007 Phazer FX last year and this was my third time out on it. I was doing about 30 on the trial and hit a slight bump and the front shock snapped at the bottom of the shaft. I have no idea why this would happen or how. As I mentioned before, I was not doing anything crazy, just typical trail riding. The sled only has about 1700 miles on it. Once the shock broke, the spring caved in which is why the shock is in the fully depressed position. Now for the question, where can I find aftermarket shocks for the Phazer FX? I dont feel like spending $400-$500 on one shock. Are there any other shocks that will fit the Phazer?
Thanks!
that shock is a rebuildable gytr shock. it might cost you a refresh as well as for the parts but it probably will only be a couple hundred $. i would reccomend getting the rest of them serviced as well as the nitrogen charge is probably gone in all of them. cannondale services and repairs them.
And since you are new here I'll clarify, Maim is referring to cannondale27 who is a mod here and hangs out in the viper section alot.
