RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
looking to find a fix for mine...... can someone point me in the right direction with a link to fixes for the headlight tabs breaking off!! thanks Jason
Wilbust
by headlight tabs, do u mean where pod bolts through to chas
I have rolled my sled a couple times and it brakes everytime. I am to cheap to spend 500 when I do this so I cut little trapazoid shaped hunks of wood and glue them in. Then put wood screw through. Works until u roll again.
Then repeat process!
copo427ss
I bent a piece of sheet aluminum and riveted on to replace the broken tab. No problems as of yet and have been through 3 seasons of riding
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
On my 06 I had fabricated a replacement ear out of a galvanized multi-purpose framing hanger. It had an ear extension to the mounting point and wrapped the top and bottom of the plastic toward the center and was epoxied and through booted to the plastic light housing. Can't find any photos.
sherlock29
Just drill a little hole or 2 depending if tab broke right off (u can see inside) and run a zip tie. U can get some real heavy ones that are actually quite strong. when removing headlight, just cut zip tie or remove the 4 10mm bolts and remove whole assembly. had to do this to a few apex's... came to about a $.50 fix...
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have a fixed one on the shelf send me yours and 50 bucks and ill send you the fixed one
quebecmoutainrider
m
My light on my 2006 apex 162 is broken..but the plastic bracket on the light has a spot where the steel brakets fit into the plastic just a bit...and then I just put the thing back together..but when it roles I dont have to fix it all the time..its lose but its not flaping or anything like that..I role it all the time..and cause it is lose now..it doesnt even come off usually
dont tell my wife..but hers is the same
gun nut
Get some life insurance.
thinksnow
Mine has been broke for two years. Not worth fixing. Light stays in place even on bad rollover. I have a new light but screw it. I will just break it again anyways.
sledneck22
sherlock29 said:Just drill a little hole or 2 depending if tab broke right off (u can see inside) and run a zip tie. U can get some real heavy ones that are actually quite strong. when removing headlight, just cut zip tie or remove the 4 10mm bolts and remove whole assembly. had to do this to a few apex's... came to about a $.50 fix...
I did this as well.
"Custom Ziptie Headlight mount"
You could even add it to your avatar as a mod! haha
lawmanbsi
threaded rod and 4 nuts. once you get the hiegth adjusted fill the tabs in with jb weld. makes the whole area stronger. I didn't fill this one in and it just broke the tab ever shorter. I bought a new one and they started to brake so then I filled it with jb weld. I would recomend to anyone that hasn't broken theirs yet to fill it in. coat the bolt with a release agent like vasaline so you leave the bolt and nut on while it sets up.
