lawmanbsi
I rolled my sled last winter and broke the rear mounting tabs on the headlight. I looked at it several times trying to figure out how I could build the tab back to mount it in the mounting holes
. I've posted a couple times looking for a replacement headlight assy. I just couldn't justify spending a $100 to $200+ on an used or new one.
1. I drilled a 1/4" hole in the bottom of the remaining tab.
2. Cut a 2 1/2" piece of threaded rod
3. placed that in the hole to mark it on top of the mounting bracket.
4. Drilled the holes
5. put 4 nuts on the rod and set light assy in place. 1 under the mount and 1 on top of the mount. then 1 under the tab and 1 on top of the tab.
Cost about $1 for both side and took about 20 minutes from bright idea to done.
I took pictures and will post them later
