dntmndr
anyone try these skis on viper ltx 137 yet, looking for feed back on if this is a easy swap worth the money.
Allan
I had them on my stx dx 146 and not got them on my xtx se. I like them and only used the stock runner that came on BTX. Great off trail and good on trail no darting. I used the stock rubbers that came on the tuners skis. But I did shim them with a peace of 3/16 plastic on the bottom, it made the skis more firm .anyone try these skis on viper ltx 137 yet, looking for feed back on if this is a easy swap worth the money.
dntmndr
thank you Allen for the info, we did mountain skis on the nytros with good results and these skis seem to be along the same lines with out breaking the bank. I'll check part numbers on the rubbers, but shimming them is easy to do also.
Allan
The ski rubber for btx will not work good for you as the spindle is different. I tried one off friends btx and and ski was to loose.thank you Allen for the info, we did mountain skis on the nytros with good results and these skis seem to be along the same lines with out breaking the bank. I'll check part numbers on the rubbers, but shimming them is easy to do also.
