aceltx09
I'm using the yamalube semi-synthetic, its 0-30.
Irv said:aceltx09 said:Its normal for a high performance 4stroke to burn some oil,especially when the engine is being broken in,but I'm just concerned about the amount and how quickly it was consumed. We will see this weekend,going for a 4 day trip a 1ft of snow 2morow were I'm going so hopefully we will be putting on 1000miles. I'm gonna make sure it is filled to the top and check it at the end of everyday.
I haven't read the posts in detail but I am curious what brand of oil your using?
I know of one brand where people(including myself) have had consumption issues using it, when the brand was switched the consumption issues stopped.
Do tell!
aceltx09
Yes, I would love to know too. I have not heard of anyone eose before this week having problems with burning oil.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Not looking to start a debate, battle or anything close to that, just stating my findings when I tried to run it in my Grizzly and Pick-up truck.
After a lot of quesions with no real answers, I did a search and found out I was the only one who had issues running it.
I think it is a small percentage who do have issues and that is confusing, as some run it and have run it for years with no issues?
Here is one link from one site but there are others.
http://bobistheoilguy.com/forums/ubbthr ... ost1649765
aceltx09
Oh, thought you were going to say the yamaha oil.
markshop
Make sure you let it warm up for 15 minites before checking oil each time. If you check oil after only 5 minites you will get a low reading and if you fill it up then it will burn it off again.
DaveRX1
My 03 RX1 would burn a half a qt every 500 miles or so (the 03's were known for this) the apex motors are not known for oil burning, but it could be. Try the ring free shock treatment and then give it and oil change and try that. Also check the oil tank for any signs of leaks.
If all else fails you MAY need new rings, but you can buy ALOT of oil for the price of a ring job.
Sportfury
- Jan 7, 2008
- Sterling Heights MI
- jakesauto.com
Oil Burning
You are not burnignit i have 7300 miles on my sled with perfect maint. I have had this issues since day one. It is in the air cleaner and then drains out the tube is is sucked into the air cleaner and then out the bottom tube. never will it burn it or see it but that where it is. Its not blow buy but a high vacume in the box yamaha said that I was crazy I burn or use about 1qrt every 1200 miles. NO SMOKE.
YamerHammer
That's the truth.....it's due to snow digestion.....the stealth air box makes this even worse. If a guy or gal is on top of this and thaws it out it isn't as bad. I got rid of the stealth air box and went to ram air, check the filter ever ride and BINGO!!!!!! I don't use oil anymore.
aceltx09
Like I said guys I take care of this thing like its my kid. I clean the air filter almost every other ride. And its never even dirty. I use the K&N Filter cleaning soap it works awesome. I just got back from my trip we put about 600 miles on and I had to add about half a quart. This sucks, I finally got my sled dialed in and I got this on the back of my mind.
