Buying my first 4 stroke this weekend(2005 Rage) 3600 miles. I gave it a good once over, looks Very Clean..However are there any pitfalls I should look out for; Cracked Spiders, Eating Primary Roller Bushings..etc
I just do not want to have to spend as much garage time again this summer/winter as I have on my Ye Ole' 94 Vmax.
Thanks for look'in out.
pro116
make shure you check the w-arm for cracks.This was the lonly year rage with the old proaction suspesion.The clutch should be fine but you can check it out.
Pro 116 -
by w-arm it is the front and back piviot arms correct? Do these crack under normal wear-n-tear or do need to be getting huge air quite offten?
pro116
the front one where the center shock is mounted ton the proaction suspension that is a common problem if rode hard.
Got it -Thanks for the quick reply-
Can't wait to pick it up this weekend-so I can stare at it in my garage......lol
Phantom
My 05 Rage has 9000 miles on it... you will love the sled.
Put gas in it and ride.
STORM-CHASER
Toad
I think you will be happy with your sled.
XCR583
I am considering an 05 Rage also. Is there any where I can look up specs on the sled, such as engine size, fuel capacity and things like that?
Snakebit
XCR583 said:I am considering an 05 Rage also. Is there any where I can look up specs on the sled, such as engine size, fuel capacity and things like that?
www.yamaha-motor.com
A bad arm:
- 13K
