Derailed
Hello all,
I'm new here, looks like a great forum. I'm looking to buy my first sled. After considering a lot of options it's came down to the 2005 RX1. I don't have a huge budget so two strokes seem like too much of a gamble to me. I could save $1000 or so by going to a 2003-2004 but from what I've read the suspension upgrades as well as valve seals makes the 2005 worth the extra $$. I found one for $3500 Canadian.. But it's got 20'000km. I've seen pics of guys with 40'000km on their OD, but how realistic is that on the motor. The guy knows all the history of the sled and says he has fixed any problems he has. Says its dealer maintained and he's got all the recipts etc.
Anyways do you guys think it's worth it to take a chance on a machine with this much mileage?
Other than the usual wear I've heard about in the rear end what else should I be looking for before I buy?
Thanks guys,
Thanks guys,
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
The engines are great but for that kind of coin you should be able to find one with lower kms.
Well lets see there is the drive shaft bearings, wheel bearings as well as the track to check for wear. Exhaust donuts steering and a arm bushings.
Derailed
I ended up buying the sled. Despite the high km (22'000). It was in nearly mint condition. Obviously wasn't used for ditch banging. There is only 1 item I found so far that I'm not sure about. The stabilization bar slides laterally about an inch. I'm not sure if this is normal or if it's broken internally some how?
Thanks again.
Thanks again.
jsjk-4-stroke
if you are talking about the transfer rod on the mono shock susp it does move or the front stabaliser bar mine moves a littli maybe 1/4 in.
