rossbowe
I am looking at 2 sleds to buy. This is my first yamaha 4 stroke. 2008 attack with 1350 miles or a 2007 apex RTX with 6300 miles. need help and any info is great.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
my vote would be the attak better ride lower miles newer sled.
rossbowe
thanks thor is it just shocks and track length the only difference
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Thought they didn't call it attak in 2008 ?Just a apex se .
Mazz
- Apr 18, 2010
- Esko, MN
- 2008 Fx Nytro RTX 40th
The attack has been in the lineup since the start of the FI four cylinders, what are you looking at paying for the sleds?
snobill
- Nov 4, 2012
- 2012 apex xtx
They quit calling it that in 08 so it must be a 07 hes looking at .
Mazz
- Apr 18, 2010
- Esko, MN
I believe the 07' rtx had the first year of the torsion spring rear end which defenatly took bumps better than the mono shock, how do you ride? If your pounding ditches and rough trail I think the rtx would be the better option.
rossbowe
Attack is $5800. RTX is $5500
rossbowe
Sorry $4500 for RTX
Where are you from?
rossbowe
Mostly on trail. I'm a bigger guy 280. Is longer track better?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
rossbowe said:Mostly on trail. I'm a bigger guy 280. Is longer track better?
Longer is much better ride, it will hookup better.
rossbowe
From Ohio but mostly ride mancelona and UP
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have rode both not a real big fan of rtx ride quality yes rear skid and track lentgh is the big diff. when it gets rought the rtx will handle it a little better but the longer track will bridge the bumps better and as mentiond it put more traction to the ground most attks have a better top end due to this.
rossbowe
