Hannibal802
- Feb 19, 2020
- Vermont
- Nytro
I just did a track change and extension with a skid relocate on my 2008 Nytro. I'm aligning the track, and I think its pretty close but I'm getting this awful buzzing sound when the track is turning.
I've almost got the adjusters the same, my finger fits between the slide rails and the track nubs on both sides but might be just a hair off. I've then tightened the axle. This is the sound it makes. Is it too tight? Or not aligned? I've checked all the bearings and replaced the ones that needed to be changed.
https://streamable.com/up2gt6
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
Just a thought,almost sounds like track clips hitting ends of sliders at back by adjusters
I 2nd that!
Hannibal802
- Feb 19, 2020
- Vermont
- Nytro
Yep forgot to trim them after putting the new ones on the rail. I trimmed them best I could without removing the skid just by removing the rear axle. Not as bad, should be OK after a little bit of riding, just no reversing for a bit till they wear.
