nytrorider28
- Nov 14, 2010
- Marion, IA
- 2014 Yamaha SR Viper LTX
2007 Skidoo MXZ 600 SDI
Past:2009 Yamaha Nytro
I installed my C&A Razor yesterday. Install was a bit longer then I expected. My question is has anyone else thought the new dampeners with mount kit are an odd fit? The kit said 2012 plus procross. So I assume it was right. I ordered as 2014 viper. That's what was sent. I got them on but with skis in the air there is very little to no ski lift. What I mean is grap ski loop and lift with ski in air and the dampner has a lot of pressure the ski has little lift. This a good thing? Thanks in advance
Rodney
- Nov 18, 2015
- Belle Ewart Ontario
- 2015 rtx se
Yes mine are the same way its all goo I have 1,400 ks on mineI installed my C&A Razor yesterday. Install was a bit longer then I expected. My question is has anyone else thought the new dampeners with mount kit are an odd fit? The kit said 2012 plus procross. So I assume it was right. I ordered as 2014 viper. That's what was sent. I got them on but with skis in the air there is very little to no ski lift. What I mean is grap ski loop and lift with ski in air and the dampner has a lot of pressure the ski has little lift. This a good thing? Thanks in advance
Muffin
- Oct 5, 2006
- Marathon, WI
- 2014 SR Viper RTX SE
The I've got close to 50000 miles and they are awesome. Pair them with slim Jim doolies.
nytrorider28
- Nov 14, 2010
- Marion, IA
Thanks guys!
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Will the OEM viper dampers not work?
nytrorider28
- Nov 14, 2010
- Marion, IA
I don't think so. I didn't try but they are a different shape for sure.Will the OEM viper dampers not work?
JAZZ04RX1
- Dec 28, 2003
- Illinois
- 2016 SR Viper LTX-LE
Just installed my blue RZ's, yes it was a little bit of a chore. C&A needs some compression on the dampener to keep the tips flat. Check out their install video on the C&A site.I don't think so. I didn't try but they are a different shape for sure.
Here is the link to the C&A resource page www.caproskis.net/resources
nytrorider28
- Nov 14, 2010
- Marion, IA
Good info! I should've known to check for a video first! They do have some compression on those dampeners, that's for sure.
jakehayamaha
Are these the skis to go with? I have Slim Jim doolys on the stock skis. No darting but I don't trust it in the corners, especially in the woods. Lots of push. Any input appreciated. Thanks
ViperJoe
Razors don't push and they go where you point them.
jakehayamaha
What kind of carbide goes good with them? Like a 6" round bar? Rtx no studs
nytrorider28
- Nov 14, 2010
- Marion, IA
That's what I'm trying on my LTX but I have no miles yet.What kind of carbide goes good with them? Like a 6" round bar? Rtx no studs
ViperJoe
I just a 9 shaper on mine but all my friends run a 6 and they have no problem.
JAZZ04RX1
- Dec 28, 2003
- Illinois
Same here RXs with 6in carbides. Had C&A's on other sleds and just made them turn awesome. Also the chassis was designed for a single keel ski. Had nothing but push in the turns with the tuner ski. Can't wait to try them!!
