TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I can figure out why my rotor is rubbing on the outside of the brake calliper. Doesn't look like anything has moved. Spacers are as follow from Chaincase out
Set screw collar, norrow collar, rotor, 2 shims and snap ring. It's almost like I need washers between the calliper mounting flange to move it out a bit.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
have you checked the rotor is in good shaper and not out of line
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
They will move?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
warped from over heating the rotor whats the rotor look like.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
you have a pic of the other side of the rotor
Dodge Ram
Did you drive with the parking brake on?? If you did the rotor might be warp from the heat as mentioned above.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
No parking brake on sled anymore .....not sure. I will take a picture today of the rotor see if it bent.......
Dodge Ram
Use a straight edge. Or you can just left rear up and run sled slowly to check for wobble.
RAMSOMAIR
caliper
Ski doos do this all the time when they bend the tunnel, since the brake is down low.
Maybe you tweaked something.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Well I did have a catastrophic failure on my secondary. But not sure how that would affect it.
RAMSOMAIR
caliper
I would bet the jackshaft is bent
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I had the chain case off .....everything looks good....being the jack shaft is supported by bearings on each end.....I doubt it's bent....also I'm pretty sure it was rubbing before the clutch explosion. Was climbing chutes and noticed coming down a really grinding noise. Also seem like the sled didn't want to free wheel when we towed it out. I noticed it then.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Well whoever guess warped rotor. Bingo.
09nytro
I'm thinking those two cal. pistons are froze up , if just one side is working your cal won't be centered on rotor ....
So take the cal apart and clean it and put new seals in ....
sgilbert
looks easy to install a beltTURBLUE said:Well I did have a catastrophic failure on my secondary. But not sure how that would affect it.
