SchelT
- Nov 30, 2014
- Oregon
- 2014 Nytro XTX 1.75
Looking for some technical advise. Thinking about upgrading to a Camoplast Challenger 15" x 144" x 2" / 2.52" pitch track (1602-137) to replace the 1.75" backcountry that comes stock. My sled is a 2014 XTX. Track is pre notched from the factory to clear the heat exchangers. Factory clutch has extroverts.
Anybody who can advise on possible issues I may run into?
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
pretty sure it clears if the track is notched. most large paddle tracks are.
SchelT
- Nov 30, 2014
- Oregon
What does it mean when Camoplast advertises "all track windows open and lugs clipped"...?pretty sure it clears if the track is notched. most large paddle tracks are.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Some tracks (usually smaller lug) some windows are closed and only clipped every third window. Most of the bigger paddle tracks have every window open and fully clipped to accomodate extrovert drivers.
P.S. Let me know if you want to sell that 1.75 BC track
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
the windows are the areas that the extrovert drivers go into to help rotate the track. they have a metal clip that reinforces the space between the windows so it doest tear. fully open is prob what your BC track is.
http://i.ebayimg.com/00/s/ODAwWDgwMA==/z/8ScAAOxyF0pThOks/$_35.JPG
that one is every window open and fully clipped
http://i.ebayimg.com/00/s/Mzk5WDUwMA==/z/RswAAOxyXzxTHlmZ/$_35.JPG
that one is every window open clipped every 3rd.
tdog1225
I put the 2" challenger track on my 09 xtx this summer. When I ordered mine through Tracks USA there was only one option for that track and it is not notched. I also called and talked to them about the notched version cause I seen one on eBay for sale. They told me that style was an older design and was no longer available. They also said this new design has stiffer lugs to reduce bending. Not sure where u are getting the track from but Best of luck.
