turbotime99
- Jan 20, 2014
Can I upgrade my 260 apex mcx without buying a new turbo I hear I can get and external fuel pump and new map and increase the boost. so anyone done this or what are my options?
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
boost
You need to send your control box to MCXpress and have it updated to 290hp or 310hp. And you will need to add a fuel pump for more fuel when the boost is at 14 for 290hp or 16 for 310hp. And I would recommend you to get a boost controller.Bind there done that and if works just fine.
turbotime99
- Jan 20, 2014
Sorry for the late reply I forgot to follow and I didn't get an email fir a reply. Anyways running these different boost with a controller would the clutch need adjustment every time I ride with different power. And would I need to get better rods and piston. or will stock handle 310 hp
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
turbotime99 said:Sorry for the late reply I forgot to follow and I didn't get an email fir a reply. Anyways running these different boost with a controller would the clutch need adjustment every time I ride with different power. And would I need to get better rods and piston. or will stock handle 310 hp
i run the clutch set up for my max preferred HP at 12 lbs-pure stock motor…..i run as low as albs (due only to available fuel on the trail) but change nothing but the boost pressure with no problems
…..i know people relaibly run 350+ HP with the only internal mod being a proper head shim..not stacked gaskets…..no rod or piston up grades unless serious HP is desired 400+.
helmic
- Nov 10, 2008
turbo
If you set your clutch for 16psi 310 for 10800 rpm when you go to12psi you will be running you rpm in the torque range that would be around 10300 to 10500 rpm the best of both worlds
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
290hp
I run 2011 APEX, MCX , UPS , 290 hp 14 lbs with Ulmers clutch kit 10800 ,premium pump gas , crazy fast so much fun !
Then when travelling, or tired , I run 8 lbs and it gets awesome fuel milage, better than stock, shifts at about 10400 but it has so much torque it never stops pulling . If I have to buy regular fuel drop to 5 lbs still fun ride.Each lbs is about 10 hp over stock. 11000 km flawless !!!
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The design strenght of the rods are 350 HP, I have run it on the edge for years, still holding up.
I have 15500 kms on it.
