jenkel
07 attack I want to change the track to a 16" vs 15" and a 1.75 lug, can anyone help with this. What size is the driveshaft? Do I need anti stab wheel kit if I go with 8 tooth anti slip sprockets
z1029384756a
16" track will hit the suspension drop brackets, driveshaft is 1-1/6" but some have pressed on the 1" drivers as well. I have 2" track and 8 tooth drivers, no anti stab kit with no problems. 1.75 track will fit with 9 tooth drivers.
tkuss
you will have to take the tunnel protectors out to fit the track in the tunnel as well.
bashley
The lugs will rub on the tunnel protectors if you don't remove them or notch the track.
jenkel
thanks for the input. Are the tunnel protectors difficult to remove? I would like a different sound maybe muffler gut or new not sure what to do
[/img]
[/img]tkuss
I used a pneumatic powered grinder to grind off the welds that are holding the front heat exhanger protectors in place. Since they are aluminum the grind off pretty easy.
The tunnel protectors I just drilled the rivets out, it was a bit hard to do since you are trying to drill the back side of the rivet. But with a bit of work and muscle they came out pretty easy.
jenkel
what about exhaust mods or changes
