Steve Raymond
- Feb 3, 2020
- Northern Ontario
- 05 rs Venture
Hey guys, I was puting my stator cover back on after changing my starte clutch bearing and this part that looks like some sort of bushing fell on the ground, I dont recall seeing it anywhere and I cant figure out where it came from
Can anyone tell what or where it might go? Oh and its off of my 05 rs venture
Thank you
Thank you
- Jun 28, 2004
- Clinton, Wi.
Looks like the bushings for the fuel tank . Should be 2 per hole on the rear ears that the mounting bolts go through.
Or for the coolant tank. Hard to tell the size of it tho
Steve Raymond
- Feb 3, 2020
- Northern Ontario
- 05 rs Venture
I never did take any of that apart, but I can tell someone has been trying to diy with this sled before so maybe just a stray part that had nothing to do with what I did?Or for the coolant tank. Hard to tell the size of it tho
Well I would say it belongs to the sled. Previous work done on it may have left it sitting around.
When I bought my used Vector I found two bolts in the belly pan. Took a few hours to find the home.
Previous owner had the dealership change the starter. Mechanic forgot about these two bolts I guess.
It happens.
It happens.
