Can you use an Apex Cluster on an RX-1
jrd699
Upstate NY
Hey guys just bought an 03 RX-1.. The cluster that came with the sled is incorrect, it only goes to 10,000rpm and has a black face (rage cluster???) I plan on changing cluster and wondered if the Apex cluster would work? I want to make sure the gauge, and speedo work, but also wanted the ability to adjust rear shock, as I am putting a mono skid into the sled. I looked at the plug and it looks the same, but sled is apart right now, so I can't check to see if it turns on and functions properly. Thanks in advance John
