can anyone tell me where the numbers are on the secondary clutch, I took it apart to clean it and must have worn off the numbers, cant find them anywhere. now when I put it back together the belt is not going back up to the top on its own. I must have the spring setting wrong. I know its supposed to be 6 on the helix and 1 on the sheave, but I cant locate the number on the sheave. I looked for a wear mark on the secondary but I am not 100 % I have the right hole. Is there another way to make sure you have the right set up. twist angle of whatever when putting it back together
