Carb/antifreeze Question
speedy75
Southeastern, Michigan
I took my carbs off to clean the pilot jets and had to disconnect the carb coolant lines. Do I need to bleed the coolant system out or can I just reconnect the lines? If I have to bleed the system how do I go about bleeding it?
Thanks!
I've pulled mine off before and never did anything special to bleed the lines. I just hooked them back up, opened the coolant shut-off and ran the sled. They system ended up self bleeding.
