So last night I broke off one of the male connectors on the bottom of the carbs that the carb heater harness hooks to. That part isn't in the area and i won't be able to get it for a few days. Will I be ok to ride with out it? Doesn't seem like it should be a big deal with out it. I also have my coolant lines blocked off.
wantboost
rode mine a year with two broken but my coolant lines are hooked up.
DC5
It will be fine. It may display a caution light while the sled is warming up but after that it will be ok.
Sweet, thanks guys.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
zross1 said:So last night I broke off one of the male connectors on the bottom of the carbs that the carb heater harness hooks to. That part isn't in the area and i won't be able to get it for a few days. Will I be ok to ride with out it? Doesn't seem like it should be a big deal with out it. I also have my coolant lines blocked off.
The electrical heater circuitry is one on when coolant temps are below a certain value and switces off when this temp are reached. No worries just let her varm up properly before taking off, the coolant that flows thru the carbs will heat the carbs enough anyway.
