crazynewf
Hey guys im sure many of you have heard this question a million times...
Im in the process of taking the carbs off my RX1 and my delima is where do I disconnect the throttle cable, from underneath the carbs or the throttle itself? And secondly where do I disconnect the master idle screw from, it seems to be moulded to the center of the carbs...Any help would be appreciated, thanks.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
You take the cable off at the carbs. It's a pain to put back on. Hold the linkage up with a long screw driver and use long needle nose to put the cable back in. There are at least two plugs that you have to unplug. One is black and the other is white. I believe that is what you were asking. When you put them back on, spray the boots with wd-40 and the carbs will go back in easier.
crazynewf
Thanks...Sounds easy enough!
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
It's not hard, just a pain. Make sure the carbs are in the boots good on the air box.
