Well after searching around, i guess i am going to go with the Mountain Performance T's since i have the carbs off now. Are you guys using the 'Yamabond' on these also at EVERY connection? Also, i assume the best way to feed the 'tees' is with a plastic 'y' fitting? Thanks!
I did not use yamabond on the billet T.s they are o ringed and seem to work fine with out it, but used it on everything else, the plastic Y should work fine, little yamaha bond on the T,s would not hurt though.
I did not use sealer on mine but on first try they leaked.I took them apart and re tightened and had no leaks.If I did them again I would use a little sealer.
