A&Shuntr
- Jan 23, 2022
- 2016 Yamaha Apex XTX 1.75
2012 RS venture
Now bear in mind these are "Edges" and not "Bolds" . Interesting note is that this am the battery level is back up to 75% after warming up. Perhaps the Edge has a battery which is more suspectable to cold (we were riding at -15c) The other thing is the odds of getting three brand new duds.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Could be. I have no experience with the edge. Where on your helmet is the edge mounted, can you send a pic.
I do have some contacts at Cardo, I will reach out to them and see if they have an opinion.
A&Shuntr
- Jan 23, 2022
2012 RS venture
Mounted standard position bottom edge left side slightly to the rear. Not a lot of options on mounting these and would look preety dorky mounted on something wierd like top or back of helmet. They say that they are only operate down to -20c, not made for snowmobiling apparently. Should have researched this more before dropping $1500 collectively on these.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Rating is the same as the bold.Mounted standard position bottom edge left side slightly to the rear. Not a lot of options on mounting these and would look preety dorky mounted on something wierd like top or back of helmet. They say that they are only operate down to -20c, not made for snowmobiling apparently. Should have researched this more before dropping $1500 collectively on these.
