phazerman39
I`m thinking of sending my center shock on my 07 Phazer Fx to Schmidt bros Motorsports to get redone. just wondering if anyone has done this and if you did, did you send the rear shock with it to get revalved to match the center one.
On the Phazer the rear shock has a much bigger effect on suspension than the center shock.I would do the rear first and then see if its worth doing the center shock.
wayfastkev
The center shock is the main culprit to all of problems with the broken link in the FX chassis. The center is way too stiff, that is why most links break on the FX chassis instead of the standard Phazer or the GT's.
They both could use different valving. But you cant go wrong on doing the center shock.
Well I changed just the rear(custom Axis) and effect was night and day better.Then I played around with changing the center.Springs(Hygear) and the shock itself and honestly it really didnt do anything anywhere near what the rear did for mine.
