64ssmax
Went to check our clutch alignment and found that the center to center of the primary clutch and the secondary clutch was short by .150 or 3.8mm.
How do you adjust that? I did a search and can not find a post on it.
Brian
Brian
if the offset is correct i would sugest living with it, it is possible that the eng mounts are getting soft
