I'm trying to replace my chain and gears. When I put the second bottom gear on, There's not enough space for the circlip. It looks like it needs another .030" It's like the shaft needs to slide out a little bit. The snap ring was tuff coming out. But not to the point where I didn't think i couldn't get it back in.
Anybody else run into this?
This happens sometimes. Use a ratchet strap to pull the tunnel together slightly.
Thanks that did it!
Just got the sled, first time working on it. Coming off an AttakGT.
I figured there was some kind trick to it.
Yamarus
- Oct 4, 2021
- Russia
- Russia
- Yamaha Sidewinder B-TX LE 153
I have a standard BTX le 153. I drive in deep snow and have torn 2 8jp belts in the last 500 km. My clutch is getting very hot. Based on the specification, I have 24T on top, 50T on the bottom, 92 chains. 8-tooth drive.
I have a manual from viper where the maximum that can be set is 21T from the top, 49T from the bottom, 90 chains. I want to replace the driver with 7 teeth. Thereby achieve greater torque and less load on the belt in deep snow. Like the M-TX.
Am I reasoning correctly? Are there other gear ratios of the upper and lower gears?
Do I need to change the springs and what weight of loads I will need.
Yamarus
- Oct 4, 2021
- Russia
- Russia
Can I install 21T on top if there is 50T on the bottom and the chain costs 92 links?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You need a 90 link chain.
21+50/2+54.19= 89.69
Yamarus
- Oct 4, 2021
- Russia
- Russia
Можно ли использовать цепь 90 от М1100/M9000 Турбо?Вам понадобится цепочка из 90 звеньев.
21+50/2+54,19= 89,69
90П (широкий 15) 2602-373
Yamarus
- Oct 4, 2021
- Russia
- Russia
Which chain is needed for 22/50? 22+50/2+54.19=90.19You need a 90 link chain.
90 will be a little, 92 - a lot. What to choose?
DMCTurbo
- Nov 12, 2005
92 but you'll have a big dogleg. I'd choose a different gear ratio myself.Which chain is needed for 22/50? 22+50/2+54.19=90.19
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Big dogleg = not a lot of room for tension adjustment + inevitable chain stretch = need a new chain frequently.92 but you'll have a big dogleg. I'd choose a different gear ratio myself.
Turboflash
- Mar 18, 2019
- Southern MN
Also possible center post rub.
Yamarus
- Oct 4, 2021
- Russia
- Russia
My friend tried to try on chains for 90 and 92 links, for a 21/50 transmission. Nothing came of it. It is not even possible to install gears on 90 chains. 90 is short, 92 is long. He has XTX. Is there a difference, besides chains and gears, in boxes between XTX, BTX, MTX?
I'll try 22/50 with a 92 chain.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
What happens when the formula works out to 86.69?You need a 90 link chain.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
You have to round up the number from the formula to the next whole integer (no fractions) and then you have to move up to the next logical chain size. If that larger chain is too long you end up with a dog leg in the chain and if the dog leg is too large the chain will not run efficiently. You typically want to stick with gear combinations with no dog leg.
Doc Harley
- Oct 17, 2016
- Here & there
Understood. I've read here in past posts that a formula ending in .19 is easier to fit then a formula ending in .69.You have to round up the number from the formula to the next whole integer (no fractions) and then you have to move up to the next logical chain size. If that larger chain is too long you end up with a dog leg in the chain and if the dog leg is too large the chain will not run efficiently. You typically want to stick with gear combinations with no dog leg.
But no discussion in regards to a resolution.
All I can assume from that is, that if you can make the .69 fit, to do so.
If you can't, you'll need to round up?!?!
I'm assuming with chain stretch, it will go.
I'm like....which is the lessor of two evils in this particular situation. Too long or too short.
