glred
Need to change the chain case oil in my 03 RX1ER, what oil do you guys use and am I correct in saying the case with reverse takes alot less oil. The dip stick reverse level is much lower.
tmk50
When I put my extrovert drivers on I replaced the oil with Mobil Synthetic Gear Oil - went with the viscosity they reccomended in the owners manual (75 or 80 weight if I remember right)
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Same here I used Mobil synthetic gear oil also!
Indy
I need to do this, where is the drain?
glred
The drain is right behind the case....lower backside
glred
anyone know the oil capacity for a RX with reverse??? the book says 8.2 oz for standard but no cap. for one with reverse
Tork
While on the subject,
I have been reading for years that some people use auto tranny fluid in their chain cases. It is an interesting thought as you would think that it would offer less resistance especially in the cold.
But the 2 fluids are so radically different. Has anybody here used it long term without any problems??
airboss
My service technician highly recommends Amsoil Synthetic, which is what I have had in my 03 since break-in.
rx1mtn
I have always used auto trans fluid in my chain cases. However, at least 2 times a year I have the gears out to change for higher altitude, and I always use new fluid. I have never seen any wear.
