SIKEWARD
local yammi dealer is out of chain case oil. I would like to accomplish this task this weekend. Anybody use somthing else other than yammi lube in their chaincase? If so what and where do I get it? Thanks!
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
gear oil
Any 80w90HD gear oil from a good brand.
- Jun 28, 2004
- Clinton, Wi.
Mobil 1 synthetic in all my sleds.
bigsky 606
manual calls for 75w gear oil i used synthetic 75-90 gear oil Castrol syntec
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I have used 75-90 royal purple gear lube, ATF only when I am doin alot of gear changes during testing for racing and now I am trying the amsoil chaincase lube this year,
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Viper_Dave said:Mobil 1 synthetic in all my sleds.
X2, 75-90 and can be bought easily
Mobil 1 everywhere....
sofunkingcool
I used amsoil before and found it to become very thick almost like syrup by the end of the season. I switched over to Shell advance synth. chain case oil and never had a problem. Also this was on my doo not a yamaha just bought the yanaha.
Daranello
Suspended
sofunkingcool said:I used amsoil before and found it to become very thick almost like syrup by the end of the season. I switched over to Shell advance synth. chain case oil and never had a problem. Also this was on my doo not a yamaha just bought the yanaha.
Interesting. Mines like water.... I used the 2000 I think
mach9
Daranello said:sofunkingcool said:I used amsoil before and found it to become very thick almost like syrup by the end of the season. I switched over to Shell advance synth. chain case oil and never had a problem. Also this was on my doo not a yamaha just bought the yanaha.
I used Amsoil 2000 also.
It was quite thin and did allow the gunge build up to evacuate when drained.
Side note, the magnetic drain plug I used in the chain case did a very good job of trapping all the fine metal particles.
sleddheadd
Amsoil series 2000 has proven itself to me Iactually ended up with no fluid in my chaincase for 1100 miles and the Amsoil still kept it protected. Very long story and I thought I was going to be replacing bearings, chains and gears but the Amsoil did what it claimed! I am sold forever!
bradthebest
lucas 75-90 . i get it cheap so its what i buy .
