paddocm
I sold my 03 Rx-1 over the summer. Just picked up a 2005 Warrior.
I know there were quite a few changes to the 05's. Does anyone have a link? or remember?
This is what I remember:
- Seat is higher
- Titainium Parts (exhuast, chaincase cover, ????)
- New rings to prevent oil usage
- Seat is higher
most of them are posted in here but a couple i remeber are, 11mm swaybar, straight rate front springs and the hand warmers retain their last setting.
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Unfortunately, also titanium exhaust Y-pipes. Front suspension geometry is better. A few metal changes to drop the weight of the motor.
MA03RX1ER
- Feb 12, 2007
- Georgetown, MA
- 2014 SR Viper XTX and 2003 RX1 w/MTN Conversion
Don't the '05s have fuel injection also?
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
EFI is in the Apex in 06
paddocm
Is the suspension the same as the 04's? Can you rebuild the shocks?
apltx08
paddocm said:Is the suspension the same as the 04's? Can you rebuild the shocks?
Yes & not sure for the shock...front suspension is the same as your '03 except for SWAY bar and links, piston rings are revised, seat is comfier of a couple of inches thicker than the '03 and somewhat better than the '04, saddleless skis (all plastic) if I'm not mistaking the brake rotor & caliper are revised, it should have a rip saw track and wider running boards than '03 & '04, primary clutch has revised rollers and ramps same as current models...
Here you go I've got all the model year brochures, I scaned you the '05 Warrior
paddocm
Thanks Apltx08!!!
apltx08
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
The 05's also had the jet and float bowl update
