krauss2005
i want to change my chain case fluid but do i have to take the cease cover off or can i suck the old fluid out with a syphon? also how much fluid will i need and what stuff should i get? it hasnt been done since i got it and this is my second winter?
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
There should be a drain on the bottom ,allen bolt,under sled and chaincase.Mine was really tight so use a quality allen wrench.
Travis Moore
It's just a bolt on my 03 (10 or 12 MM, forgot). Just use ATF in the thing, works great. It takes around 8.5 ounces I think. Again, all from memory of last year.
T
T
jimmie d
Should be a bolt inside tunnel behind chaincase.
Jim
Jim
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
jimmie d said:Should be a bolt inside tunnel behind chaincase.
Jim
That is correct
I just changed mine on my 04 Warrior with 7700 miles on it, going on my 4th season and I took the cover off to inspect the bearings and found that they where all well lubricated and looked like new
All I have to say is I've been using Mobil 1 75w-90 Synthetic Gear Oil from the first oil change to date
ToddMeister
- Jun 30, 2003
- Bay City, MI
- Yamaha SR Viper LTX LE
- YAHOO
- tmeister73
Bob Miller said:jimmie d said:Should be a bolt inside tunnel behind chaincase.
Jim
That is correct![]()
I just changed mine on my 04 Warrior with 7700 miles on it, going on my 4th season and I took the cover off to inspect the bearings and found that they where all well lubricated and looked like new![]()
All I have to say is I've been using Mobil 1 75w-90 Synthetic Gear Oil from the first oil change to date![]()
I also just had my 04 Warrior chaincase apart for inspection, and all was well. I also use Mobil 1 75W-90 Synthetic Gear Oil.
low slung
- Feb 16, 2005
I use YAMAHA OUTBOARD GEAR OIL,thats what the dealer gave me.Works great but it turns dark after every season of riding and i change it every summer(flows better in the heat)
Travis Moore
low slung said:I use YAMAHA OUTBOARD GEAR OIL,thats what the dealer gave me.Works great but it turns dark after every season of riding and i change it every summer(flows better in the heat)
Not suprizing-I think anything slippery with a thickness somewhere between cooking oil and ketchup will work fine in the chaincase. It's just a chain thats lubricated by oil splashing around. ATF is cheap, easy to find and seems to work fine.
