hopewell64
ok guys time to start the summer mods ( boy i hate summer ). i want to change the approach angle on my sled and i have an idea, i would like to know if anyone else has done this, i am gonna put in a camo extreme 2.5x16x156 in it with ice age rails ( dont know which ones ) and move the skid back in the tunnel to lower the approach angle (dont know how far back )i will probably go with kmod drop brackets to clear the 16 inch track. any ideas to make this work. also i am gonna mod the the tunnel , (pictures would help, thanks ). i already did an under tunnel exhaust. thanks happy summer .( ya,right )
bholmlate
Good question. It will be interesting to see where this post ends up becasue It is obviously something that needs to be addressed on the older Nytro's
Yamaha obviously figured out they needed to address the issue because they reduced the approach angle on their 2010 line.
unfortunately I havent come across any post on here yet talking about how to reducing the approach angle on the 08-09 models
robbie
Drop and roll for Nytro
Avid Products is working on a drop and roll kit for the '08 and '09 Nytros. You will be able to run the 3" long paddles with an eight tooth driver. Approach angle should drop 15 degrees.
hopewell64
well i will check with avid later on . but i was thinking maybe artic cat rails, and with the 3 inch longer track moving the skid back aproximately 2 inches should lower the angle. i havent had a chance to aproximate the the angle change by moving the skid back 2 inches. but it should help. thanks for the replies
PwdrNut
- Jan 16, 2005
- Salida, CO
- www.haboost.com
We have relocated a few skids. We have moved them back between 1-3 inches. We have also moved them up into the tunnel more. This does help with the approach angle.
We will be doing another of these this week and take a picture to show the difference.
hopewell64
hey that sounds great, will be great to see how that looks. do you know to what degree the approach angle changes to . did you guys go with a longer track after moving the skid. thanks
how did yamaha decrease the angle for 2010? did they move the case
hopewell64
lol aha
hopewell64
any luck with that sled you guys were moving the skid on. getting ansy to start on mine , thanks
Tookes
Check with "Rx1M5" he did this awhile back.
evil1
- Sep 26, 2008
- fort mcurray, alberta
- lewishillbillies.com
heh pwdrnut ---c'mon pics please we are waitong for the results,,,no pressure
PwdrNut
- Jan 16, 2005
- Salida, CO
- www.haboost.com
I hate to say that I forgot to take the pictures. I'll see if I can get some this week.
evil1
- Sep 26, 2008
cool,,appreciate the reply!
murph
Alternate approach angle solution?
When installing a Timbersled skid and also trying to lower the approach angle....
Instead of drilling new holes in the tunnel, couldn't you just move the rail mounting points closer to the front of the rail? The Timbersled mount kit already has the back arm mount pieces and you could make something similar for the front.
In theory, this would effectively reduce the approach angle and you could move the shock mounting points in relation to the arm mounting points so the shock ratios were retained.
Look at the 2010 nytro rails and their front arm mounting point-- looks like they did something similar.
Does any of this make sense? Has anyone tried it?
Pwdrnut any pictures of what you have done??
YamaMTX
- Feb 7, 2009
- crosslake MN
- 2009 Yamaha nytro and polaris 600 rush
Robbie how is that kit coming for the approach angle and what will the pricing be?
