bigdave
- Dec 18, 2003
- sylvan lake, Michigan
- 14 Viper LTX SE, 14 Viper RTX SE , 08 FX Nytro , 07 FX Phazer, SOON 2017 Sidewinder LTX LE Blue
Hey guys what is the best/easiest way to change out the track on my 05 ER so it has reverse I have never take a reverse case apart and was looking for a couple pointers !!
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Take a picture of the outside and inside of the gear case. When you take the parts out stack them in the reverse order so they will be in order when it goes back in. DON'T lose the little spring between the two little gears. Trust me, it will take 1 hour to find it. Other than that, it's not a bad job. Take your time. Make sure when putting it back together you get the shift fork in the grove on the gear. There is a small bolt on the front of the cover in the middle. That needs to come out or you won't get the cover off.
x2 on the pictures. there is a step by step posted up in the tec section if you run into trouble.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
Did mine last season the toughest part was getting the shift fork back in just be patient and dont force it! Not a bad job plus theres plenty of help here! good luck
bigdave
- Dec 18, 2003
RX1 track
Thanks guys i will take a pic and hold my temper
Dave
Dave
- 12K
