Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
All,
The silder buttons in my Nytro secondary were trashed so I started looking around for some new ones only to find they were $18+ most anywhere. I then looked at the buttons in the secondary on my '99 SX and they were the same. So I looked them up on ebay because my local dealer did not have any and I found these Yamaha buttons:
<http://www.ebay.com/itm/261318448483?item=261318448483&viewitem=&sspagename=ADME:L:OU:US:1120&vxp=mtr>
for $5.99 each or so I thought. I ordered (3) of them and ended up getting (9) total for around $28 shipped. The qty listed (1) on ebay which apparently means (1)pkg of (3) buttons. Next time you need some I would recommnend this seller as the price was definitely right and the shipping was quick!!!
MadMax
But yet when I wanted to order new wear bars they were priced "EACH" I almost screwed up and only ordered one.. Hmmmmmmmmmmmmm. MM.
aftermarket buttons tend to shear off or wear out faster than oe. had it happen a few times and now will only use oe as it almost cost me a helix and clutch 1/2.
you might want to edit the link.
Rich Kay
OEM only for me on this part....
SHAMARKEN
I tried to run the SLP with no luck ended having to buy a new helix...stick with OEM .....
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Same here, I have had the cheap ones simply fall out. Never again...go OEM even though they are still a rip off.
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
I just ordered 3 from Royal Distributing here in Ontario. $1.89 ea. Compared to $15.00+ each through Yamaha, with taxes would be over $50.00.Gouging B*&^&es. I cannot afford to support Yammi any longer. Yamaha can't even competitvely sell a tiny piece of plastic. They will get no more money from my pocket, a mans gotta eat. Cheers.
Mills
- Dec 4, 2007
guys - these are factory OEM buttons. I think they have a million of them and just want to get rid of them which is why they are so cheap.
grumpysanta
I COULD USE 3. CAN YOU MAIL ?
Mills
- Dec 4, 2007
Grumpy -- go to the ebay site I put in my first post and you should be able to get them there.
did you read the guys ad on ebay? it says it replaces the Yamaha part # lower in the descrition, not it is that #. that is why I thought they where aftermarket. if they are Yamaha oe, great!
Metallicat
If they are indeed Yamaha OEM then great. If not you are in for a surprise. We tried them once on a Polaris XC. They made it a few hundred miles before ruining the helix.
