blkhwkbob
My buddy's RX-1 was burning oil like crazy. I found some GUNK brand oil treatment at Menard's for about 3 bucks. Poured it in the oil tank and so far, so good. Oil consumption less than half of what it was this weekend doing 400 miles plus. 1/5th the cost of Ring Free.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
what you need to do is do a shock treatment with the ring Free an change oil & filter after when you look at the oil it should be really black an use a 1-2 oz of ring free after an that will fix the problem.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
darv said:what you need to do is do a shock treatment with the ring Free an change oil & filter after when you look at the oil it should be really black an use a 1-2 oz of ring free after an that will fix the problem.
X2 ring free might be expensive but its cheeper than the alternative
Indy
viscosity would be increased dramatically by adding snake oil. The sled maybe just a little hard to start in the mornings. lol
darv
- Aug 9, 2005
- 08 Apex 40th LTX
you do not add to oil you ad it to the gas the last bottle cost me &12.95 for 12oz an I add 1oz to every tank so that pretty cheap if you as me.
Indy
darv said:you do not add to oil you ad it to the gas the last bottle cost me &12.95 for 12oz an I add 1oz to every tank so that pretty cheap if you as me.
Darv, read the OP's remarks again. I was responding to him.
stomper
I have been trying to find ring free at several yamaha dealers around me and no one stocks it. Most of them said that seafoa does the same thing and does it better. I am just repeating what they said
Indy
OP- where did you go?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
yes you can use sea-foam it work great also
blkhwkbob
What do you want to know? You add a bottle to your oil tank and your oil consumption goes down drastically. It may not be RING FREE FROM YAMAHA, but if YAMAHA was PERFECT in everything they make, they wouldn't be selling so much RING FREE, would they?
Gunk oil treatment in a blue bottle. Do a search on it. It works and it's a lot cheaper than Ring Free. And the engine hasn't blown up yet.
ebockus
ive seen sea foam in a spray can at canadian tire, im not sure how u would use it though, any thoughts?
KBrian
I don't know about the spray can-think it's a spray lubricant. But Can Tire sells Seafoam engine treatment in a white can with red markings (900mL)
Pour into fuel tank about half the can with a fill-up to shock the motor. Works great to clean up the carbs and the combustion chamber IMO
ebockus
i picked up "ring free plus" from my yamaha marine dealer today. snowmobile dealer did know what i was talking about. it says to consult dealer for shock treatment on the bottle. the dealer didnt know, im wondering what you guys do for a shock treatment?
thanks
thanks
Should you do that much, ride easy.
My EGT readings have dramaticaly increased using maybe not that much.
As soon as i go wot, yellow warning after 5 sec.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
pour 12oz in tank run sled normal when you have burned that tank of gas make sure you change oil and filter. when you look at oil it should be very black after then run 1-2 oz in every tank and it should help with your problem.
