yakkk
- Nov 13, 2006
Hi, the orange warning light on my dash is on and tne engine light flashes in a cycle of two's. It a 2003 rx 1 . Any help would be great.
check the oil first. most likely the '03 uses it.
yakkk
- Nov 13, 2006
checked oil it is full. seem to run hot but coolant is full too.
doo900
are you low on fuel??????????
yakkk
- Nov 13, 2006
no, i have the orange warning triangle flashing and below that the check engine symbol flashes in a cycle of two on - then off.
look in the manual if you have it because that is a blink code for diagnostics.
yakkk
- Nov 13, 2006
I don't have a manual. I was hoping someone on the site had one and could help me out. thanks
RedRocket
yakkk
- Nov 13, 2006
I ended up having a bad grip. i replaced it and the warmers started to work again and the check engine light went off. Thanks for the help...........................
Jaybaar
- Feb 22, 2021
- New Hampshire
- 16 SR Viper LTX DX
03 Yamaha RX1
Hi Yakkk, I am brand new here with a new to me 04 RX1 - I have the exact same issue. Did you order the grip from Yamaha or aftermarket? Any assistance would be greatly appreciated, thank you!
