check engine light 2003 rx 1
yakkk
Hi, the orange warning light on my dash is on and tne engine light flashes in a cycle of two's. It a 2003 rx 1 . Any help would be great.
checked oil it is full. seem to run hot but coolant is full too.
no, i have the orange warning triangle flashing and below that the check engine symbol flashes in a cycle of two on - then off.
look in the manual if you have it because that is a blink code for diagnostics.
I don't have a manual. I was hoping someone on the site had one and could help me out. thanks
The owners manual just tells you to go to the dealer. If your light is flashing in series of two, then there is a problem with your grip warmer according to the service manual. See attachment for page.
I ended up having a bad grip. i replaced it and the warmers started to work again and the check engine light went off. Thanks for the help...........................
Hi Yakkk, I am brand new here with a new to me 04 RX1 - I have the exact same issue. Did you order the grip from Yamaha or aftermarket? Any assistance would be greatly appreciated, thank you!
