sportster64
How difficult is it to clean the carbs on the 05 vector ?
Is it as critical to clean them as it is with the 2-strokes ?
Can you burn down a piston if the carbs are blocked like the 2strokes - or is it much less probable ?
Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
Its not bad at all. No more work than a 2 smoke. Just take your time and do one at a time. They should be cleaned, you will be supprised what you will find. Not as critical as a 2 smoke.
