om600
- Sep 15, 2013
- Nova Scotia,Canada
- www.oakridgecabinetsmillwork.com
- osp viper outlaw
anybody no if 10 tooth anti ratched drivers with an 1 1/2 intense track will clear tunnel protectors in a 2006 apex.Thanks
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
That's going to be close.
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
No ,been there done that..you will need to trim the track were it lines up with the tunnel protectors.
FLYBYU
Re: 10 tooth anti ratched drivers
I agree, It won't fit. I have 9 tooth with same track and no studs.
helmic said:No ,been there done that..you will need to trim the track were it lines up with the tunnel protectors.
trailnazi
will the 1.5 intense fit with the 9t as you say you have. or is it still hitting the sled
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I've installed a 1.5" lug Crossover track using 9 tooth extrovert drivers in a '06 Apex based sled. I did have to remove the heat exchanger protectors and the tunnel protectors for proper clearance. Other than removing the protectors there's no other problems with that set up.
