clutch cracking woes
type809
Columbus, WI
Hey guys, I have an 03 Bender TRX running a stock motor with 110 oct. @ 12lbs. Using Bender's stage II clutch kit. Went to change the secondary shoes because they looked worn, got the clutch apart and notice cracks behind the shoes, just to make sure I wasn't seeing things I applied a little finger pressure and yep the damn support fell right off, after looking at the cam, I could see it was "tapping" alum on alum, not good. I'm thinking I don't want another yamaha secondary, and I'd need a new helix anyways, so I'm looking at the team secondary, and was hoping for some opinions, also my primary has that "groove" in it that all the yami's seem to get with the 8dn belt. So I'm up for a new primary as well, and setup. My plans include getting a new primary set with "overdrive" using a dalton blk/grn spring, and the new quick adjust flyweights, but have no idea on the team setup to go with this, was hoping someone could help. I am willing to pay a bit for a "clutch kit" if the setup is close.
Call Ted and get the supreme secondary . larger diameter it uses cat helixs and springs . I think mine was the best cash spent on this build to date.
